ORO light Pods are Out
Rubi04TJ
Single piece unit encompasses Stop/Tail/Turn function as well as Reverse Indicator and a Side Marker Light .
Unique, eye catching design.
High density LED pattern.
Each housing has 63 LED's; 48 red, 12 white, and 3 red side markers.
No drilling required on Jeep Wranglers and CJs+.
Low profile design measures less than 1" thick.
Taillights are black when not lit.
Clear acrylic lens and high intensity LEDs deliver crisp, sharp light.
High impact Polycarbonate housing provides extreme durability.
UV stabilized housing and lens resists discoloration.
Adhesive reflective material included to allow user to comply with most vehicle regulations.
Sealed, shock and vibration proof solid state design for years of reliable service++ .
Heat shrink connectors included for wire connections to OEM harness.
Warranty: Unit replacement if one LED fails within 90 days or 3 LEDs fail within 12 months.
+ Models other than Jeep Wrangler may require drilling to attach. OEM license plate mount on Jeep TJ’s may require trimming to clear the outer diameter of LiteDOTs™.
++ Service life is rated at 100,000 hours.
+++ A flasher replacement may be required to eliminate "Fast Flash". Some flasher models available separately.
Additional License Plate/Third brake lite combination also available soon.
LiteDOTâ„¢ MSRP: $195.00 per pair.
I want these so bad.. requires no cutting of the body so you can always go back to stock lights.
Steve said:
Those suck, they're too costly and they're not flush mount. Glad I have cheap trailer lights the past 2 weekends in a row would have been very costly. I pushed one of my lights right through and into the tub. Also, at Paragon I had the rear of my jeep kissing a tree right over the lights. The cheap $10 lights take the abuse. ORO seems like a big gimmick company.
you suck.. i like em :lol: :wink:
I like them as well, seen them on ROF and I thought they looked good, and best thing, no need to cut a 4" hole in the tub...
however the price is way high, most I would say is $120.
I change taillights almost as often as I change diapers. :roll: I'll stick to my $10 lights.
I think it would take a lot to break these as they are a solid peice of plastic stuff (not sure what it is) but the hole thing is one peice and doesn't have a plastic sheild covering the LEDs like others.
Price is a little high, and for me these will be off in the future, i have more important things to get first.
Steve said:
I bet you like their air suspension too. :lol: I can see Zach bouncing and rolling through the hoods of Meriden. :grinyes:
Your actually right.. I also like ORO U-turn and Swaylock.. Maybe i should buy some stock in them too if they ever go public :wink:
