heat the center up a bit and some big treaded rod and tighten it up.... maybe?sean_cj7 said:How do you intend to get tubes back in. I'm pretty sure it a heavy press. I'm interested in you thoughts, its something I've been thinking about doing myself. But I've heard you need go size press, tonage wise.
i would still draw them together with the rod or somthingbeaker said:Got a large propane torch / garage heater. Going to get the center nice and hot. Pack the tube in dry ice and slid it in and let everything equalize and hold it tight.
Sufficient temperature differential can make a press fit a loose fit. Thus no press needed.
Well that's the theory. I'll have to tell you how it goes.
