Radiator Woes
  • Thread starter Thread starter CJKarl
C
CJKarl
It all started Sat night when I came home from the meeting to throw a tune up in the jeep for the Sun. RI trail cut. As I pull into the barn I notice a puddle under the rig. Drats, antifreeze. Come to find out the seam near the top let go...and it's only 1 1/2 years old. :rolleyes:
So, the trail cut is out for me, now I can't find a radiator on a Sun. I call up Detour and he has one that might fit. Go to his shop, pull the radiator, do a little booty-fab to make it clear my steering shaft and install it.
DANG! couldn't get the bottom hose to seal. :confused: Come to find out the bottom neck WAS cracked after all. I must have bent it when I pulled it from the GC donor.
Off to ACME this morning, "have one by noon, full warranty" Pick it up this afternoon, have them unpack it for me so I can check it out....F**ked up! The weld was snapped on the mounting flange. Soooo they will have ANOTHER one for me Tue afternoon.
All I want to do is have a radiator that doesn't leak, is that too much to ask??????????????????????
Update tomorrow.
Detour said:
Hold on to the donner, bet I can fix! :Tools:
It's an easy fix. Solder joint cracked where the neck meets the body. I'll hang on to it.
ACME...life time warranty. ...Unable to get me a replacement that doesn't come F--ked from the factory. :rolleyes: :confused:
I've got a couple of them here at the house if you need one to get you by until a good one shows up.
Didn't even think to call you Sun. Probably even closer than Detours shop. Oh well, supposed to have it Wed. :rolleyes:
I did score a brand new Optima from East Haddam Sean today for $90 it's the 800 CCA model.
Radiator, upper and lower hoses are in. I think it looks good, but need a final check when it's lighter and WARMER out.
