RE Lift stuff
Greenhorn
I have some used RE 4.5 stuff up for grabs.
Front Coils  $75 pair
They need big time cleaning and paint.
They are 21 in. long and used to be 204lbs. when new.
They are a little tired. Had to use 1.5 poly spacers to maintain height.
XJ Leaf springs   $100 pair
Just a little too good to only use for parts.
One spring has a broken leaf and will need to be taken apart,
Its the 2nd leaf, so if it were my delima, Id use a stock spring as a donor and fix this one.
They have 4 deg. pinion shims on them.  Arch (chord height) is 11 in.
I have some awesome shackles (that I kinda want to keep) but maybe....
RE Controll arms -Fixed- $100.
These were recently rebuilt but have worn loose again.
You probably can get away with just cranking them tighter and cleaning them up a bit.
Includes the tool to wrench on them. If  I look, I may have some various parts for the ends.
I?ve been an RE user for 8 years so Im sure theres stuff around here.
Lowers are 16 in. long.  Uppers are 15-3/8 in. or so (whatever theyre supposed to be for correct caster)
$250 or BO if you take it all?
BUT first I really need a decent front axle for my Cherokee, OR, rebuild the one I have in it.
Willing to trade.
I  also need shocks.
My front static height is  24 in. (stud / bar pin)
Dont know rear length now-will look ( bar pin / hoop )
:mrgreen:
Pictures added (I think)
https://www.flickr.com/photos/17923897@N05/albums/72157657538813539/with/20994294282/
