Rear Steer on the cheap
You can do the busted knuckle one on the cheap.  I sent tom a link a while back when we started talking about this project
So there hasn't been much of an update lately, still waiting on a few parts, but the bulk of the work is done. The last steps are to install lug studs and rotors, put the gears in the axle and fully weld once I know it fits correctly.
Once the lug studs are in and I can bolt tires to it, I'll take the Willy's apart and make sure everything fits before I go too much farther.
In the mean time, I'm going to work on the pump and where hydraulic lines will be run
Sent from my motorola one 5G ace using Tapatalk
Engine bay is already pretty tight on that, right? Are you planning to run an electric pump?
