J
J.R.Cabral
Anyone know if the rear view mirror with compass on a 2003 TJ can be turned back on without taking it to the dealer? Every time I disconnect the battery this thing goes out.
Section 11DESCRIPTION
An automatic day/night mirror system is an available
factory-installed option on this model. The automatic
dimming inside day/night rear view mirror
system is a completely self-contained unit that
replaces the standard equipment inside rear view
mirror. This system will automatically change the
reflectance of the inside rear view mirror to protect
the driver from the unwanted headlight glare of
trailing vehicles while driving at night. The automatic
day/night inside mirror receives ignition
switched battery current through a fuse in the junction
block, and will only operate when the ignition
switch is in the On position.
Contained within the mirror is a compass/temperature
display as well as two LED reading lamps.
The automatic day/night mirror sensitivity cannot
be repaired or adjusted. If any component of this unit
is faulty or damaged, the entire automatic day/night
inside rear view mirror unit must be replaced.
OPERATION
The automatic day/night mirror is equipped with
three buttons: the left switch for the left LED lamp,
the right switch for the right side LED lamp and the
center switch for the compass/temperature function.
Pressing the left and right switch simultaneously will
turn the auto dim function on or off. A green light
next to the right button will indicate when the dimming
feature is activated. The mirror also senses the
backup lamp circuit, and will automatically disable
its self-dimming feature whenever the transmission
gear selector is in the Reverse position.
The compass/temperature display provides the outside
temperature and one of eight compass headings.
Press and release the center button once within 3
seconds to display compass/temperature (Fahrenheit).
Press and release the center button twice
within 3 seconds to display compass/temperature
(Celsius). Press and release the center button three
times within 3 seconds to deactivate the feature.
A thin layer of electrochromatic material between
two pieces of conductive glass make up the face of
the mirror. Two photocell sensors are used to monitor
light levels and adjust the reflectance of the mirror.
The ambient photocell sensor faces forward, to detect
the outside light levels. The headlamp sensor is
located on the mirror housing just to the left of the
switch and facing rearward, to detect the light level
received at the rear window side of the mirror. When
the difference between the two light levels becomes
too great (the light level received at the rear of the
mirror is much higher than that at the front of the
mirror), the mirror begins to darken.
DIAGNOSIS AND TESTING - AUTOMATIC
DAY/NIGHT MIRROR
For complete circuit diagrams, refer to the appropriate
wiring information. The wiring information
includes wiring diagrams, proper wire and connector
repair procedures, details of wire harness routing
and retention, connector pin-out information and
location views for the various wire harness connectors,
splices and grounds.
(1) Check for a blown fuse. If OK, go to Step 2. If
not OK, repair the shorted circuit or component as
required and replace the faulty fuse.
(2) Turn the ignition switch to the On position.
Check for battery voltage at the fuse. If OK, go to
Step 3. If not OK, repair the open circuit to the ignition
switch as required.
(3) Turn the ignition switch to the Off position.
Disconnect and isolate the battery negative cable.
Unplug the wire harness connector from the automatic
day/night mirror. Connect the battery negative
cable. Turn the ignition switch to the On position.
Check for battery voltage at the fused ignition switch
output (run/start) circuit cavity of the automatic day/
night mirror wire harness connector. If OK, go to
Step 4. If not OK, repair the open circuit as required.
(4) Turn the ignition switch to the Off position.
Check for continuity between the ground circuit cavity
of the automatic day/night mirror wire harness
connector and a good ground. There should be continuity.
If OK, go to Step 5. If not OK, repair the circuit
to ground as required.
(5) Connect the battery negative cable. Turn the
ignition switch to the On position. Set the parking
brake. Place the transmission gear selector lever in
the Reverse position. Check for battery voltage at the
backup lamp switch output circuit cavity of the automatic
day/night mirror wire harness connector. If
OK, go to Step 6. If not OK, repair the open circuit
as required.
(6) Turn the ignition switch to the Off position.
Disconnect the battery negative cable. Plug in the
automatic day/night mirror wire harness connector.
Connect the battery negative cable. Turn the ignition
switch to the On position. Place the transmission
gear selector lever in the Neutral position. Place the
mirror switch in the On (the LED in the mirror
switch is lighted) position. Cover the forward facing
ambient photocell sensor to keep out any ambient
light.
NOTE: The ambient photocell sensor must be covered
completely, so that no light reaches the sensor.
Use a finger pressed tightly against the sensor,
or cover the sensor completely with electrical tape.
(7) Shine a light into the rearward facing headlamp
photocell sensor. The mirror glass should
darken. If OK, go to Step 8. If not OK, replace the
faulty automatic day/night mirror unit.
(8) With the mirror glass darkened, place the
transmission gear selector lever in the Reverse position.
The mirror should return to its normal reflectance.
If not OK, replace the faulty automatic day/
night mirror unit.
STANDARD PROCEDURE
STANDARD PROCEDURE - COMPASS
CALIBRATION
AUTOMATIC CALIBRATION
The compass is self calibrating which eliminates
the need to manually set the compass. When the
vehicle is new, the compass may appear erratic and
CAL will be displayed. After completing one 360°
turn with the vehicle traveling less than 8 km/h (5
mph) in an area free from large metal or metallic
objects, CAL will turn off and the compass will function
normally.
MANUAL CALIBRATION
If the compass appears erratic and CAL does not
appear, you must manually put the compass into the
calibration mode. To ensure proper compass calibration,
make sure the compass variance is properly set
before manually calibrating the compass.
To put the compass into calibration mode: Turn the
ignition to the ON position. Press and hold the center
button for 6 seconds to change the display between
VAR (compass variance) and CAL (compass calibration)
modes. To recalibrate the compass, CAL should
display for a complete 1 1/2 360° turns in a area free
from large metal objects or power lines. When the
compass has been calibrated, the CAL symbol will
turn off and the compass will function normally.
VARIATION ADJUSTMENT
Compass variance is the difference between magnetic
north and geographic north. In some areas of
the country, the difference between magnetic and
geographic north is great enough to cause the compass
to give false readings. If this occurs, the compass
variance must be set
If I'm going to spend $90, I'm gonna get the book. If I could get the CD (or download) for cheap I'd do it. The thing is, I don't want to spend $90 on it. :lol:Steve said:Your have to order the FSM from Daimler Chrysler Tech Authority. They have it on CD in PDF format, so you can print out what you need for the job and not worry about getting it dirty. None of the other manuals come close to the FSM so it's worth the cash if you can do the work on your own.
https://techauthority.gltghosting.com/webapp/wcs/stores/servlet/ItemDisplay?catalogId=10051&storeId=10051&itemId=18942&langId=-1&categoryId=80160&parent_category_rn=80104&qty=0
