Reel Driveline U-joints
NomadJeep
Administrator
anyone heard anything good about Reel Driveline H2O PROOF U-Joints
seen then in a few places.
Designed for the Serious Off-Roader. Forged Body from high strength Alloy Steel. Cryogenic Treatment for increased strength & durability, a Stronger Trunnion with larger diameter radius reducing fracture points. Waterproof Seals keeps water & mud out and keeps grease in. Filled with Special Waterproof High Temperature High Pressure Grease. These H2O Proof U-Joints are 40% STRONGER & More Durable than O.E. U-Joints. NO B.S. GUARENTEE! Break It - We Replace It!
Cryo doesn't do much if anything
Since it says it has larger trunions, either it uses thinner caps, smaller bearings or no bearings.
None of which I'd trust in a rear driveshaft.  Front's only if you have lockout's.
Spicer and the other major u-joint co's design theirs for maximum life (miles).  Pretty much anything from these small co's is going to give up life for strength.
