G ghiradelli777 Guest Mar 12, 2006 #1 I cant for the life of me get these things off the hinges...... :swear_mad: can someone give me a bit of advice
R Rubi04TJ Active member Mar 12, 2006 #2 take the bolts off.... while wiggleing the door open to close, lift from the bottom, it may take a while but with a little wd40 and time it will come loose.
N NomadJeep Administrator Mar 12, 2006 #3 Rubi04TJ said: take the bolts off.... while wiggleing the door open to close, lift from the bottom, it may take a while but with a little wd40 and time it will come loose. Click to expand... X2
JeepinMaxx Active member Mar 12, 2006 #4 ghiradelli777 said: I cant for the life of me get these things off the hinges...... :swear_mad: can someone give me a bit of advice Click to expand... SawZawl :mad02: Just kidding - spray with PB Blaster or Liquid Wrench. Then do the wiggle thing (on the doors )
S Shrek Guest Mar 13, 2006 #5 not that it will help this time but a litte anti-seize will help bunches next time
G ghiradelli777 Guest Mar 13, 2006 #6 thanks guys i dont wanna miss a beautiful day when i could take the doors off....
G ghiradelli777 Guest Mar 16, 2006 #8 are you being serious??? it is a 92 YJ.....i hit tree bracnhes with it.... :rotflmao:
G graves14 Guest Mar 19, 2006 #9 screw driver up from the bottom of teh hinge tap it with a hammer while lifting....
