The steering box on the YJ is shot I think. Here is the story,
Rebuilt box 2 years ago. Used to over heat after an hour or so on the trail. Pump would wine, put in a cooler and new pump just in case. However the steering ability has not been the same for a long time. And in the last year, it has barely worked once you get the tires off the road.
Pump does not wine anymore, and there is no foaming over heating but I think the box is just had it. It does not leak,but it also acts like a manual steering car when you try and turn the wheel while not moving.
So do I try and see what is up with my box? Anything that can be tested?
or I can try and get a Wagoneer box, or better yet a Durnango.
I have about $200 to spend on an attempt to solve it. So that rules out ARG or PSC as much as I would love them.
So do you think I should try the Durnago route?
Junk yard: $120.
Rebuilt at Napa: $211.
Here is a thread on the durnago set up.
http://65.42.106.152/forums/showthread.php?t=636551&highlight=Saginaw
Junk yard: $120.
