Stock on a CJ5 and YJ
hotrod
I was just wondering for reference what would have come stock on my two jeeps in terms of axels, gearing, tranny and t-case. I have a 1974 CJ5 that came stock with a 304 ci and three speed. I also have a 1995 YJ with the 4.0L and the automatic. Thanks for the info!
95 :
Chrysler TF-999 3-speed should be your tranny... I think  :question:
NP-231 t-case
Front Axle:
High Pinion Dana 30 front end with a vacuum disco.
If it is a 95: it will have these u-joints
If it is a 95 1/2: it may have the larger u-joints
Gears: most common was a 3.07 but you could also have: 3.55
Rear Axle:
Dana 35 (old snap happy)
any other questions about a YJ?
Frank that is what I thought on the Auto, but I did a search when I was looking and mostly guys were saying they got 3.07 in their 93-95(auto)... which I thought was low for an auto, but they were bitching pretty good so who knows.. :grinyes:
just hope you have 3.55, way better if you go to a 31
Thanks for the info guys! The gearing doesn't matter too much on the YJ because it will be getting 33's sooner or later. (hopefully sooner than later :biggrin:)
