Red Rocker
So I got some half doors and replaced the hinge pins, one was broken and they were worn anyway.
Any way I hung the door on the jeep and the hinges needed adjustment to close the door properly, loosened two of the three torx bolts and the third stripped, so torx is no longer an option
So question is how do you guys with these rusty TJ's get the bolt out once it's stripped ?
Drill and easy out, or drill the head off and remove hinge and then use some vice grips on the stub that's left or is there some other trick?
