SWR Meter
  • Thread starter Thread starter method84
M
method84
hey guys, I recently purchased a Cobra75WXST CB radio that should be arriving this monday so I can hook it up. The antenna already came this week along with the mount. The antenna is a firestik II I belive and I bought both the mount and antenna from arizonarockyroad.com which I highly recomend. Anyways, I ran the antenna wire to my glovebox (thats where the CB box control will be) and its ready to go. My question is does anyone have a SWR meter that I can use at the great american jeep raly? Im not really sure how to use them but I know that the antenna has to be dialed in with the SWR meter. Thanks in advance :bowdown:
The antenna should be pre-set to the 20 channel range. You should be OK with that setting. I have the Cobra all in the handset setup also. Good unit. I hope you went with the 4' antenna
I actually got the 3 foot antenna thinking the 3 foot is already insanely huge poking up out the back and if I went with the 4 id be hitting everything :o
i have one. remind when it gets close to bring it. need a hacksaw or cutoff wheel to trim the ant to proper length.pete
The antenna does need to be checked and tuned if needed a high swr will damage the radio
I have one in the back of the Jeep now
I'll try and make sure it's still there at the rally
bonestack said:
...need a hacksaw or cutoff wheel to trim the ant to proper length.
The firestick's have are adjustable, you don't need to cut the antenna.
