JeepinMaxx
Last week, we installed a SYE kit in a spare transfer case (thanks Damon & Bruce!)
Well today I decided to install the SYE case into the YJ. Removing the old one went OK. Swapped the speedo gear into the new case and put in a new front yoke seal.
Then went to install. Benchpressing a T-Case up into the Jeep isn't fun. Had all the holes lined up and couldn't get it to mate. Struggled with it for about 45min. Then dropped it down to double check the input shafts. Counted the splines - stock T-Case had 23 splines and the SYE case had 21 splines :twisted: :twisted: So back to the bench and swapped the SYE to my stock t-case. Only took about 15min (Thanks to Damon's training - now Bruce and I are SYE pros!)
We re-installed the the T-case (went in easily), hooked up the linkage and the front DS. Everything was finally coming together!
Then, we went to install the rear shaft. It was at least an inch or two too short :twisted: :twisted:. It would have 1.5" of spline showing to mate to the pinion yoke (at ride height). I'm sure it would pop out at droop. That's what I get for buying a used Tom Woods :sad:
So now I have to order a new shaft. Hope to have it before Mayhem.
The only good news was the angles looked OK!
Sorry for the long story. I just had to vent :rant:
