Tires off quick???
cjshloman
Anyone know of a place that is CHEAP!  to get my 5 33" tires taken off my rig??  I want to sell them and give them up at the M&G on the 28th.  Anyone advise taking them off with the hi-lift...safely ???    Let me know, Bull.
Take the valves out, put them under your jeep and HiLift the beads off them. Pop them off with a tire iron.
i have found that a forklift works better and quicker than even a tire machine to break beads.  if you have access to one that is. remove the stem cores, set the fork tips angled down right at the edge of the rim by the bead and push them down. pulls the bead right off.
Bull -take the valve stem out - run over the sidewall with your truck (with the wheel off the jeep :wink:) .  Then use tire irons or prybars to separate.  - or the highlift with the heel on the bead and the claw on the bumper of a heavy vehicle.
i think thats all and good, but i dont want the sidewallas all bashed up becasue I am the one looking tobuy those tires.......
Bull, Like I said, I never did that before, but if you need a second set of hands, give me a call.
I found this on the web. It looks like breaking the bead is the easy part, it's wrestling with it to get it completely off the rim...
Tire Maintenance
| Home | Tech Section |
Braking the Bead
Dismounting a Tire From the Rim
Remounting the Tire
Setting the Bead
Parts/Tools Needed:
- Valve core puller
- High lift jack
- Board (2"x6"x2')
- 2-3 lb. Hammer
- 2 large flat screwdrivers or tire iron
- Armor All for lubricant
Barking the Bead:
1. Remove the tire, put on the spare
2. Place tire on top of the board and under a solid jacking point
(i.e. the front or rear bumper)
3. Use the core puller to remove valve stem, to let out any remaining air
4. Place the highlift jack along the bead on the tire, but not on the rim
5. Begin jacking, the tire should begin to compress and soon there should be a "poof" as the bead of the tire brakes loose from the side of the rim
6. Repeat the process for the other side of the tire
Dismounting a Tire From the Rim:
1. Place the tire on a flat surface, with the outside face of the tire up
2. Use tire iron to pry tire up the tire over the rim, take small bits and work your away around the entire rim
3. Stand the tire up on its edge, put screwdriver between the backside of the rim and the front tire wall, pry and hold a moderate force, now with the hammer smack the tire right were the tire is beginning to sperate from the rim, do this from side to side until the rim is free
Remounting the Tire::
1. Place the outside tire wall on the ground
2. Set the front of the rim in at an angle and give a push to seat it for prying
3. With the tire irons work the tire back on, alternating from side to side, until the first half of the rim is in
4. Turn the tire and rim over (face up)
5. Use tire irons to pry tire over the rim, alternating from side to side until tire is on the rim, it may help to kneel on the tire to keep it from coming back over the edge
Setting the Bead:
1. Bounce the tire on the ground a couple of times, this helps push the tire bead out to the edge of the rim
2. Make sure the valve core is still removed
3. Spray ArmorAll around the tire beads
4. Let lots of air into the tire, the tire should begin to take air and then make a poping noise when the bead sets on either side
5. Install the valve core, complete airing the tire back up
Bull, if you are in Dire need, there is a garage that I used to work on that I could probably do it at...
but only on Wednesday....
