Toyota tercel spark plugs?
J
jeepsquire
so I just helped a friend of mine put new plugs in her '98 toyota tercel 4cyl & I was geting pissed cuz I could only find 2 of them.  Lo and behold there were only 2 wires in the new wire set from Nappa as well.
It cant only have 2 plugs can it?  :eek:
That doesnt make any sense to me at all.
2- cylinder?  :grinyes:
Maybe they only recommend changing two at a time :eek:
I checked on-line and many parts sites list OE 2 wires required :question:
Maybe one wire feeds two plugs?
The other 2 are underneath the direct fire coil packs (2) A single 10mm bolt or 2 holds them onto the valve cover, this car uses a waste spark type system hence 2 coil packs and 2 plug wires.
Oddly enough the New Hemi is designed the same way. But with 16 spark plugs :eek: Have fun paying for that tune up.
I think I saw those.  Later, after she left, I wondered if the other plugs were under them.  I'm poping over to her place after work to look.
Thanks.
