Horn
I need to do an imperfect tub repair. Mine has been splitting down the seam on the driver’s rear corner for a while. Recently split all the way up. I’m thinking I could use a thin flat file to clean up both sides of the split. Then use some automotive seam sealer to seal it back up and put a ratchet strap around it to hold it together while the sealer cures. This is one of a few spots on the tub I need to do something about in the next couple of years. I expect eventually this corner will be covered up by corner guards once I shell out the cash for them but that’s not a this year thing.
