H
HookSetSteve
Gonna stem up my new rims just wanted some suggestions on what stems to get
Steel or standard?
Thanks
Steel or standard?
Thanks
NomadJeep said:metal note... rubber stems are practically free... and if you rip one,,, just pop the bead with your high lift and put the new one in 2 seconds... then pray someone can help you reset the bead :wink:
NomadJeep said:... then pray someone can help you reset the bead :wink:
I've seen those a while ago, seems like a sweet idea. I dont know anyone that's used them though. Let us know how you like them. I may pick up a set of them when I get some new meats.d0nnyg77 said:Steve, just found these in my new 4WD Hardware rag. I'm sure they've been around a while. I am getting a set this week. I'll let you know how I make out. For only $15, I'll take the chance.
http://www.4wd.com/shop/productdetail.asp?model=tj&productsku=VS407C
