D
Drdan524
I have just started running my girlfriends 92 Yj around since she is coming home from college for Thanksgiving. As I was driving, I noticed that it doesn't stay at normal operating temperature. As it runs it will go up to about 210 degrees like normal, then once it hits about 210, it drops quick to about 150ish. Once it drops, it slowly works its way back up to 210 and it repeats. If I let it idle in place, it will do the same thing except much slower. It does this all the time, whether the heat is on or off. But you can notice the temperature difference coming through the heater. When it is at 210 the heat works good, but after it drops, the heat gets cold again. Any ideas what this could be? It is a 92 YJ with 2.5L and manual transmission. Somebody put a 2 inch body lift on it so there is no fan shroud on it. Any ideas would be greatly appreciated.
Thanks
Dan
Thanks
Dan
