What other parts do I need?
gorilla_skater
Administrator
Staff member
We'll be doing Hub Bearing Assys and Front Axle U-Joints on my XJ tomorrow. I just want to make sure I have everything I need.
2- Hub Bearing Assys
2 - Spicer 5-760x U-Joints
2 - Cotter pins for the axle nuts
Do I need any other parts?
gorilla_skater said:
xjmark said:
A can of anti-sieze. :wink:
Got that. Cool.
One spare U-Joint (in case we screw one up and drop bearings on the floor :wink:) also good for a trail spare :mrgreen:
Tools on hand:
BFH
Air hammer chisel (in case BFH doesnt work)
Air impact tools
U-joint press
other-AutoZone is 5 miles away
Want to keep your new bearing in good shape.
Torque them:
3 rear 13 mm bolts 75 ft. lbs.
Most important
Hub Bearing Center Bolt 175 ft. lbs. (36 mm socket)
A VERY BIG HAMMER and a roll of duct tape. Oh yeah and more beer.
Torque them:
Most important
Damon, we were going to torque the unit bearing bolts to the 75 ft lbs (we almost called you about this- didn't want to bother you) , but we were afraid we would snap the bolts (13mm head).  Draz used the breaker bar to bubba torque them though :wink:
I rented a 250 lb torque wrench to do the spindles ($80 tool for 2 min of work :twisted:)
JeepinMaxx said:
Torque them:
Most important
No breaker bar used... I didn't torque the hub units, I only did the calipers going back in...  :smile:
I DID "Bubba Torque" KakiRubie's winch to his bumper though...  :mad02:
MasterDrazhar said:
JeepinMaxx said:
Torque them:
Most important
I forgot - It was the brake caliper bolts that had a spec of 77 lb-ft of torque per the Chilton's.  We were afraid to snap those bolts
Frank you would be correct in not going that tight,,,
here is the correct for the next time...
3) Coat caliper mounting bolts with silicone
grease. Then install and tighten bolts to 15 N·m (11
ft. lbs.).
however I never torque these...  the only really important one is the center hub nut.
Damon - th
ft. lbs.).
Damon - thanks for the input!  The Chiltons/Hanes manual have steered me wrong in the past :swear_mad:
