Ok, so here is my long winded problem,
When I had the brain storm to use the revolvers I had to make some changes to have them clear the rear frame and stop hitting the Kilby Gas tank skid. Now I had seen this done elsewhere so I had the Spring eyes moved to below the frame like in this pic of the rear...
Now this was a good thing, it gave me a little room, made my pinion angle a little better, and also added some lift.
Now to make the Jeep level the front also needed to go down to match, so this was done up front.
Now the problem is my Caster is all off... Instead of being (OEM) 8 degrees positive, I am at 2. Which make my pinion angle high, at 11, and also makes my steering squirlly... so my question is this, what would you do...
I can take all this off and go back down, (welded very well so it can be a little hard to get off) Or I can shim the front end. If I put a 4 degree shim in the front, my caster should go to 6, (not bad) and the pinion would drop to 7.... which I have no idea if that will even help anything being my tcase angle is at negative 4... (see other post about angles)
What do you all think?
