Wrench Festuvus!
kakirubi
Looks like we are going to have another day of wrenching at the KakiMax Garage!  Saturday 1/6/07 starting at 8am!
So far on the agenda is the following
1.  4 inch Teraflex lift on Rubi13's 03 Rubicon.
2.  1 inch Daystar Body lift and 1 inch JKS MML on My Rubicon.
3.  T-Case upgrade for Tina.
4.  D35 to D44 upgrade for Jeff.
5.  Shocks and Radiator for BigRedJeepster.
6.  UCA and LCA and Trackbar for Rey.
I'll add to the list as we go.  If youv'e been to my garage you know we have 2 bays and a small shop area so it can get a little busy.  Depending on weather we can have some work going on outside as well.  Plenty of parking and I sure there will be some refreshments.
Remember the more help we have, the more projects we can get through!  Even if you don't have anything going on with your Jeep right now please come on down and Check it out.
Don't forget Tigger/Tina PM'ed a reservation for the second bay for her T-Case upgrade :wink:  (should take less than an hour...
Thanks Bruce!
For BigRedJeepster, he should be ready for broken rear upper shock bolts just in case. Spray 'em with PB or Deep Creep. I'm not sure what the best way is to deal with them if they break. I heard that you can drill them out and on some XJ's, there is a hole where you can fish a nut in. I was lucky when we did mine, non broke, and I bought a set of these from Detour so I won't have to worry about it...
Unfortunetly the rear driver side already broke and i do need to drill a new hole. what did u buy from detour because i no thats not what it looks like where i bolt mine onto.
I need to take a number too.  Need to winterize.  Take off the skid which vibrates on my exhaust and makes all sorts of noises plus change from chunky tread trail tires to winter-drivers.  Shouldn't take long.  Do you think you have room?
Detour how much am i looking at spending on the 2 rear ones??
This is lookin to be a fun day! :mrgreen:
Anyone who is interested in learning something, COME ON DOWN! :beerchug:
u should talk my hubby into helping he helped a friend build a willy's from the ground up and it came out great he got alot of awards for the truck in car and truck shows
Nick, what do you need done?  Have you got your T-Case out yet?
[/quote]
honestly i have had literally no time with work..and me and my buddies planed to do it today and tomarrow but i came down with a horrible case of Strep.. so i will hopefully this clears up and i can yank it out before the fest
i will need some directions to your garage on sat. iwould like to put my bellyup skid up flush with my frame and readajust the pinion angle ,my skid plate is bent a little on the passenger side hopefully someone has a torch to heat up the plate to flatened out the wrinkles. :question: :razz:
