Here's an update... It's only been 1 day, but totally happy with it. The ride is not that bad with the AAL's, and the vibes are just slight between 40-45 mph. The measurements right now (from hub center to the bottom of the fender) are 19.5 Front and 20.5 Rear. If I'm correct that the stock measurements are 17.5 Front and 17 Rear then the front is spot on with the 2" spacer but I'm sitting about 1.5" high in the rear which is really 1" more than I expected. This is somewhat understandable because RE only had 2.5" Full Length AALs.
Do you think the rear will settle a little more? OR should I start thinking about raising the front? :grinyes:
