NomadJeep said:
Out of all of the 4" YJ lifts I have done, it seems the correct shim is 8 degrees. (however, this all changes as soon as you put a SYE on or raise the t-case drop.
I am not sure about what the RE comes with, call them and ask. If not, RE actually has the best shims out there. All steel, and be sure to get the new center pins.
there is no way that any of us can say it will be this or that... it is a hit or a miss.
Some Jeep take 8, some 6 etc....
As I said before, I have found 8 to be a good shim on many of the YJ lifts I have done.
If you have the money, buy both. (6 & 8 degree) Then you have them. (first call RE like I said above because I read somewhere that RE already comes with 6 instead of the normal 4 degree)
Now remember, you can put in the 8 and in 1 month it could still be wrong ones your springs start to sag and the angle changes again... it is allways a crap shoot when it comes to shims.
The best way to do a YJ lift with Shims.
Put the lift on, put the SYE in with the driveshaft. Then get your measurement, and then spend the 2 hours taking the rear apart. Then if you do that, you know you put in the right shim. Either way you look at it, if you put the 8 in from the start you may be pulling it back apart anyway, so just do it write the first time.
(if you do the rear, just snug the u-bolts and measure. The you can take them apart quick when you need to put the shim in. and you wont have to buy new bolts being you did not stretch them twice.)
When you take the rear apart, you dont have to undo much at all, leave the leafs in the Jeep, with the shackles bolted and all. Leave the shocks, driveshaft all of it. Just unbolt the u-bolts, jack the axle a few inches up from the leaf springs, and take apart the center bolt of the spring and swap with the new bolt and shim.
Dont drill out the shim, use a new center bolt through it. and you can save more work by using a c-clamp and keeping the the leafs all tight and compress to each other. The you just hit the center bolt out and pop new in... cake. if not, all the leafs separate, drop and it is a bitch to line then all back up and get the center bolt in.....
