Being I have a YJ, and cross this bridge all the time... here is what I would recommend.
Skip the Body Lift, the 11 bolts to pull it apart are usually frozen, and then the welded nuts inside the tub, which you cant get to end up turning because the welds break, then you have to spend $$ to get someone to cut open the channels to get to them. Also the steering shaft is often frozen and wont come apart, and when you do a BL, it has to extend it an inch. A BL on an older jeep is just not worth it... you could be like me, who's dealer told me to put a 3" BL on because they would not warrantee my Jeep if I changed the suspension, but a BL was ok,,, now I have cracked mounting points all over the tub... (fixed thanks to Detour)
A spring over is the best, and the end all, but it is a big cost when you add in steering, SYE, Driveshaft and upgrading out of the Dana 35. If you are planning on spending $500 + then save and go spring over, (note: it will give you 5 inches with factory springs)
If you are planning on 2.5 inch of lift, just know that your leaf springs will sag, and end up with about 1" to 2" (ask Detour)
If you go 3.5" you will have to lower the t-case or do the SYE,... this will put you into my situation... you will end up spending over $600 for kit, shocks etc... then you will end up doing a SYE because you will get annoyed with the T-case drop being you lifted it 3, but only gained 2" Also, you will notice that other people are flexing all over the place, and you are not... (soa vs sua)
I would recommend keeping an eye out for a used 3.5 kit, (BDS or RE) people get rid of them all the time when they go spring over. Also, all you really need out of the kit is the leafs, and a good set of shackles. You wont use most of the other crap in the kit...
You wont use the Track bar brackets being the rear you will never notice is missing, (everyone takes it out) and the front will limit you axle travel by 30% and you will find it is not a hug benefit with driving and often not noticed. (if you have good springs they will keep your axle nice and centered, and remember CJ did not have them) (however if you feel you need one, I have it)
Sway bar disco, well you may end up leaving the sway bar off, like most YJ people, but if not, the ones that come with the kits, (which most don’t) are crap anyway, so you will end up buying JKS Quicker Disconnects.
T-case drops, call me I have a few :wink:
and drop pitman arms are not needed on the YJ, even though they give it to you...
So, find a used kit, buy some M.O.R.E. Boomerang shackles, cheap longer travel hydro shocks and discos if you like...
Also, you will be able to fit larger tires if you buy some TJ flairs on it, plasma cut the rear wheel well to TJ flair size, and you will be able to fit most tires.
If you have specific YJ questions, I have crossed every bridge, I have a lot of failures under my belt so I can tell you what not to do... :rotflmao:
Last thing, if you go with a cheap kit, you get a crappy ride, or a premature sagging leaf…
Bad Kidney lifts:
Rough Country
SkyJacker 3â€
Superlift
Good Lifts for YJ’s
BDS
Rubicon Express
Old Man Emu
Black Diamond
