R RidinRyan Guest Jun 10, 2005 #1 I have a tom woods rear drive shaft from a YJ, dont know the lenght as of this minute but ill measure later and get it up here but will it fit on a TJ? Need to know if i should save it to use or off it, thanks!
P pyagid New member Jun 10, 2005 #2 as long as it is the proper length, i believe the axle yokes are the same, so it will work -Paul
Marty Moderator Jun 10, 2005 #3 If it does not fit, I have a YJ with a POS driveshaft that should be replaced. Let me know if you want to get rid of it../marty
R RidinRyan Guest Jun 10, 2005 #4 will def let you know marty, does anyone know the exact length of a TJ rear driveshaft so i can measure and be certain?
