Groundhog
As I was laying out my lift parts and spraying all the rusted bolts, I noticed that the rear stainless brake line extender from Rubicon Express does not look like it will fit into the stock set up that is attached to the rear axle.
Do I no longer use the stock set up or did they send me the wrong part? Their website pics are all the same no matter what model number you click on so I can't verify that way. The model number I have says its for a CJ/YJ/MJ,(Â RE1513 Brake Line SS Rear YJ/CJ/MJ - Extended rear stainless steel brake line 22" long), but they don't list another 22 inch option.
I have an email into them but I figured I'd post the queston here as well.
Also, do the rear coil perches on the axle have to be moved as I rotate my axle up to match the drive shaft? Or is the 3.5 inches of lift not a big deal as far as the springs are concerned ? Just wondering before I start wrenching. :question: :question:
