ZJ coil springs in a TJ??
  • Thread starter Thread starter Disjeep92
D
Disjeep92
Does anybody know if you can use ZJ front coils in the front of a TJ? I was asked by a friend of mine from Http://endlessmountainsjeep.net/phpBB2/index.php . He said that ZJ coil springs are a little bit taller then TJ coil springs so he was wondering if he could swap them. Any help would be greatly appreciated.
I know that zj v8 springs are about 2" lift for an XJ. I think they are a little taller than TJ springs as well
-Paul
yeah they net about three inches in the front. then you take the stock tj front springs and move them in the back to gain 3 inches back there.
I also heard of using crown vic springs for the rear but i do not know what years or anything more about that.
Rubi04TJ said:
yeah they net about three inches in the front. then you take the stock tj front springs and move them in the back to gain 3 inches back there..
I thought TJ rear springs were alot fatter in diameter??
yes they are but they still fit
I know RE ZJ springs are all designed for the V8. Might be a little on the stiff side in a TJ. Front of my heep weighs about 2700 lbs. My 2 cents.
Kevin C.
have to remember that incase i ever get a tj
