zj modifications
  • Thread starter Thread starter mfr8888
M
mfr8888
looking to add certain modifications to make my zj more trail worthy. I'm thinking of a budget boost, 2" lift with a set of 31" tires thrown in, I realize any modification done on the suspension of a grand cherokee can be touchy. Does anybody know a good mechanic in the ct, mass, or eastern ny area that specializes in jeep modifications. thanks
We do.......lol. Where are ya at? We could have a wrench fest some day. Lots of tech experiance here on the board. Bull.
ive done a little bit. this is mine
DaBrode said:
HE STOLE CJJULIE'S AVATAR!!!!
GET HIM!
:smt067 :smt068 :smt070 :smt071 :smt075 :chainsaw:
That's what happens when you get your avatar from the "Avatar Gallery"!
Bullet said:
jeep.xj.4x4 said:
GET HIM!
It's better then getting it from the Red X gallery :P 'cause that's all I can see for yours 8)
That must be a problem with the settings on your browser. I see it fine, I can also type in the web address and see it too.
Detour said:
Adding a budget boost is very simple work, couple hours & your done.
Be sure to start hitting all bolt connections with penitraiting oil a week
before you start. :wink:
Anyone know if the "adjustable" coil spacers work on ZJ's?? :roll:
The front ACOS fit the XJ TJ and ZJ. The rear ACOS only fit the TJ though.
well pucks work good but i prefer the f / r it gives you an extra 1 1/2" for $100.00 more to bad you xj guys cant do that :smt064 either way you will have to ge new shocks why not do it right?
as long as everything is tight, bushings tie rod ends ex. you shouldn't get death wobble.
be sure your steering stablizer is good as well and your tires are ballanced.
also make sure to keep an eye on your shock tower bolts, ive seen them losen up and couse it as well.
