Hydro assist on my LJ
gorilla_skater
Administrator
Staff member
Since my “next upgrade” poll was almost unanimous for Hydro assist, let’s talk about light bars. JK
My current steering set up is ORO u-turn steering linkage with stock pump and gear and a Metal Cloak track bar.
I contacted ORO and Steve sent me the info below.
“So, that's a RockRam, the PSC kit is more popular I believe. BUT one thing to know, you need to use a 6" ram for this setup.
The standard kit for the TJ's utilize the ram to the draglink, and that kit utilizes an 8" ram (that needs to be limited to just over 6") however when we mount the ram to the tie rod (its far better here as the ram then only puts the force on each tie rod end, NOT thru the draglink and to the tie rod.)
The standard kits typically include a set of brackets to weld to the tie rod/draglink, BUT we do not recommend welding to the Uturn Tie rod, as it is heat treated, so the clamp shown there is the best way. Poly Performance and I beleive PSC themselves offer a clamp for 1.375 diameter (happens to be stock JK size as well) And these clamps now allow the rod end for the ram to mount directly to the clamp. I'd recommend ordering that clamp separately.
SO, with the 6" ram, mounted with the fixed end into the stabilizer mount on the TJ/XJ axle, and the 4 or 6 bolt clamp on the tie rod there is room for that all to be happy.
I do recommend getting the steering/geometry all setup and Jeep driving nice BEFORE mounting the ram (especially if you are replacing the gear, do this with the ports to the ram plugged) This will determine how far the tie rod will move from left to right, stop to stop. You will want to do this, move it full right turn to the stop, then put a piece of tape on the tie rod and measure to the mounting bracket for the stabilizer (doesn't need to be the center, just to the face is good, you want a spot that you can repeat the measurement easily.) and then swing to the far opposite turn, and now measure the distance from the tape to the same bracket point again, this should be just under 6", and we recommend adding a washer or two inside of the ram so that the ram travel is limited to what the steering stops allow. IF the ram moves farther, then turning and holding the wheel will over-pressurize the ram and push on the tie rod. You want the ram to match the steering travel, allowing full travel of the steering plus not over working the ram by pushing beyond where it should.
With the steering all adjusted for proper ride/drive and centering of the steering wheel, then install the ram to match the travel range, and then hook up the hoses and bleed the system and drive!!!!!”
Tha only real question is which card it's going on
I have that ORE gift cert I'll probably never get around to using
So are you going to mount the ram to the drag link since your track bar still mounts in the factory location on the axle? Not sure how you would be able to mount to the tie rod with the track bar down there.
Per the ORO guy, he says mount it to the tie rod.
"however when we mount the ram to the tie rod (its far better here as the ram then only puts the force on each tie rod end, NOT thru the draglink and to the tie rod.)"
My first step is to decide on how to get the box ported:
1. Bleepin Jeep will replace seals and port my steering box for $280
2. Redhead steering box with ports for $636
3. PSC Big bore XD box for $1,050.00
4. AGR Super Box 2 - 228352 for $571
I would convert it to a normal Saginaw box rather than the Mercedes dual rate box. For 2 reasons, the dual rate box is expensive to replace ( or it was in the past ) and the Saginaw boxes are very plentiful and sourced easily.
From what I have read, PSC is the only company making brand new boxes. Everything else is performance reman. If you have the money, the psc is worth it.
I agree that you should. Mine is mounted to the tie rod as well. My question was how. Is there enough room between the diff cover and the tie rod to mount it on the drivers side of the axle? My ram is mounted basically in the stock track bar location, but a little higher. But my track bar is mounted up higher on the passenger side of the axle.
Ian mounted his off the diff cover and runs a plate steel cover, but that isn’t really an option with the ox locker.
The PSC and AGR boxes are Saginaw. You have to shorten the steering shaft to make them fit the 2003+
Is the PSC a Saginaw or just styled after one? For JKs it’s a completely different beast compared to stock.
You could chop off a couple of inches from the stock intermediate steering shaft or if you have a shaft from an earlier TJ it will fit with no cutting since it is already 2 inches shorter than a 2003+
That's the route I took when I did mine.
PSC is a good option, but their prices went up recently.
Northridge has a 15% off sale once in a while though
I'm pretty sure they use a 6-inch ram for a stock LJ front end, I got the kit for a one-ton axle and that came with a 8-inch ram
