RedJeepster1
Hey guys. So I was working on my YJ this week. Having fixed the leaks in the 9” rear axle, I was hoping to also get the rear brakes working better. Since I put this Jeep back together last year, the brakes have always been horrible. Pedal engages where it should but is very soft all the way to the floor. It does harden up near the floor, but basically feels like I blew a rear brake line.
The current setup:
The rear axle has brakes off of a Cadillac Eldorado. They are single piston calipers with a lever for the e brake. These were on the axle when I bought it.
All brake lines were brand new last year. From the master to the calipers.
Booster is stock for an early YJ.
I changed the master cylinder to one off of a 78 Grand Marquis. It’s 1.125” bore, direct bolt in to the stock YJ booster, and designed for front and rear disk brakes.
Proportioning valve is summit racing brand adjustable. Currently bypassed because I wanted to rule it out as a culprit.
Brakes have been bled multiple times. I get a good flow of clean fluid out of the rear bleeders. On both sides. This was the case with the stock 1” bore master as well as with the new 1.125” bore master. I currently have bypassed the proportioning valve to rule it out as the culprit. It made no difference. Line from the body to the rear axle is stainless braided and new last year. Only parts I have not replaced are the calipers themselves and the short section of rubber line that runs to them. Neither the calipers or the lines look very old.
Any thoughts? Anything I am missing? I can lock up the front wheels currently, so rod length appears to be correct. Distance to engagement is nice and short. After trying to lock up the brakes multiple times, rear brakes are still cold. I can see the calipers quick but it’s such a small amount it isn’t doing anything.
The current setup:
