redjeep
Moderator
I watched a couple install videos for the No-Slip and it looks a lot like a normal lunchbox locker EXCEPT is has a couple of sleeves internally that look like they allow the axles to rotate at different speeds during a corner. I think of it as having a little slop between the axles. My guess is that if you jacked up the rear axle and held one wheel, you would be able to rotate the other wheel maybe 15 or 20 degrees before the locker stops rotation. This would be enough to keep the locker from having the tires scrub in a corner. Seems like it would be great in a light Jeep.
The Full Case Detroit in my TJ acts similarly I think. You don't even realize it's in there on the street.
