Marty
Moderator
Cool stuff....copied from http://www.jpmagazine.com/techarticles/154_0708_weakest_to_strongest_axles/viewall.html
_____________________________________
Ever wonder how your Jeep's axles rank against the rest of the axlehousing world? Wonder no more. Here's how we rank 'em from the geeky weaklings to the all-star axle jocks. Of course, you'll find a few axles missing from the list. Many axles don't make good swaps, are not readily available, or they just have no aftermarket support to speak of.
When compiling the list, we took the strength of the entire axle assembly in stock form into consideration. This included the gears, housings, axleshafts, and so on. Of course, there are multiple versions of many of these axles. Some are significantly weaker than their newer counterparts, and we've made notes where we could. We also threw in some tips on what to watch out for and keep in mind, whether you're looking to make a swap to something bigger or keep what ya got. To identify what axle came in your Jeep, check out "Axle Axtravaganza" in the May '07 issue.
Front Axles (weakest to strongest)
19. Dana 25
It shares similar closed-knuckle parts with the Dana 27 and 44. It has several weak points when overtired and overpowered, including axletubes, differential gears, shafts, and steering joints.
18. Dana 27
See Dana 25-also has a marginally larger ring gear.
16. Low-pinion Dana 30
The shafts and small 260-sized U-joints are its weakest parts. Also has weak axletubes. However, it has lots of aftermarket support.
17. Closed-Knuckle Dana 44 (FSJ)
See Dana 25-same smallish, coarse spline outer shafts and dinky U-joints like the 25 and 27. The '71-and-later inner shafts are large 30-spline parts. The '71-and-earlier axles have weaker 19-spline shafts.
15. Toyota 8-inch
A stout axle for its compact size. Aftermarket Birfields can beef it up. It can actually make for an OK Jeep swap, but it's often frowned upon for being an import axle.
14. High-Pinion Dana 30
It's one of our favorites when found without the axle-disconnect system. Early versions can be converted to larger U-joints with factory and aftermarket parts. Air time will bend the tubes. This axle has lots of aftermarket support.
13. '06-and-earlier Rubicon Dana 44
Same outer ends, steering U-joints, and axletubes as Wrangler Dana 30. The only real gain in strength is in the gears and inner axleshafts (larger diameter and more splines). It has lots of aftermarket support but limited available ratios if you're using the stock Rubicon differentials.
12. Toyota Land Cruiser
They're getting harder to find, but they're still usable for a Jeep (albeit an expensive oddball possibility). It's not a popular swap or one that makes sense unless you have the axles already. Even then, you may be better off selling them.
11. Chevy 10-bolt
It's marginally weaker than a GM or FSJ open-knuckle Dana 44. They have slightly smaller 28-spline shafts and thinner axletubes. However, almost all the 10-bolt knuckle components and stub shafts interchange with the open-knuckle Dana 44. It's a usable full-width axle, but we'd prefer a Dana 44.
10. Low-pinion Dana 44 (FSJ, GM, Ford, and Dodge)
Perhaps the most swapped-in axle in history. Both left- and right-side pinion versions are common and lots of parts interchange between different 4x4s that used some version of the Dana 44. It has a good cost-to-strength ratio and can be easily upgraded in many areas because it has plenty of aftermarket support.
9. High-pinion Dana 44
Only found in some Ford 4x4s. It's a little rare, but the ring-and-pinion are slightly stronger than the low-pinion 44 gears when used in a front application. There are fewer ratios available than what can be had for a low-pinion version. It's a decent swap for a full-width axle with a driver-side pinion.
8. '07-and-later high-pinion Rubicon Dana 44
It features stronger tubes than the 44 axles in the previous model TJ Wrangler. It's sure to see plenty of aftermarket support, including complete assemblies available from Mopar.
7. Low-pinion Dana 60 (M-715)
It has weak stub shafts and weak axletubes. Also has huge, nearly unusable brake drums. It's not a popular or a particularly good swap.
6. Low-pinion Dana 70 (International and Dodge)
Rare. Not all that desirable.
5. Dana 50
Ford Super Duty full-width ball-joint style solid axle. Kind of an underdog. It's possibly a good swap for Jeeps that need a driver-side differential. It has a decent amount of aftermarket support.
4. Low-pinion Dana 60
It's a kingpin-style, full-width axle commonly found in GM and early Dodge 1-tons. They're normally way overpriced in today's used axle market. However, the 60 has unbelievable aftermarket support. You can build a complete axle using all aftermarket components. There is also a newer ball-joint Dodge version, which is slightly weaker.
3. High-Pinion Dana 60
It can only be found in Fords in two versions. There is an older kingpin design and the newer Ford Super Duty ball-joint version. The kingpin style is typically considered stronger and more desirable. It's also more difficult to find and more expensive. Like the low-pinion version, this 60 has unbelievable aftermarket support. You can build a complete axle using all aftermarket components.
2. Rockwell 2 1/2-ton
The later-model axles with Spicer-style U-joint shafts are most desirable. The 2 1/2-ton has unbelievable gear, steering joint, and housing strength. The coarse spline shafts, particularly the stub shafts, are weak when compared with the rest of the assembly. There is lots of aftermarket support to adapt and strengthen this axle, but only one gear ratio: 6.72:1. The large and heavy drum brakes are not all that usable for a Jeep, especially if mud and water are in the plans. Due to overall size, gearing, width, and weight, it's not a good axle for tires less than 44 inches tall.
1. High-pinion Dana 70 (new GM version)
It's still a little rare, but can be found on newer GM medium-duty 4x4 trucks. Very few ratios are available, and there are virtually no aftermarket parts for it even though it's likely the strongest usable front axle for a Jeep swap with tires up to and more than 44 inches in diameter.
Rear Axles (weakest to strongest)
27. Dana 25
It has several weak points when overtired and overpowered, including the axletubes, differential gears, and two-piece axleshafts.
26. Dana 35
It has a very weak and flexible housing that causes C-clip axle and differential problems. Unfortunately, it has unbelievable aftermarket support despite its weakness. However, consider any upgrades to this axle a Band-Aid for the real problem. If you're running it hard (especially with a locker) and it hasn't spit out its insides and it's not bleeding gear oil out of the pressed-in tubes and plug welds, it soon will be.
25. Low-pinion Dana 30(Mexico CJ)
It's a rare pile, but it's out there. It has weak tubes, a smallish ring gear, and two-piece axleshafts.
24. AMC 20 (CJ)
The AMC 20 is marginal in a stock application. It has a very weak and flexible housing that can lead to other problems. The two-piece axleshafts are notoriously fail-prone. Much like the Dana 35, this axle is best swapped out if you are planning to spend money on it or run larger-than-stock tires.
23. Chevy 10-bolt
Much like the Dana 35, it has a very weak and flexible housing that can lead to other problems. An abused Gov-loc is a death warrant for the 10-bolt rearend. It's not a swap-worthy, full-width axle for Jeeps.
22. '06-and-earlier Wrangler Dana 44
The smallish axletubes (same as Dana 35) can flex and cause carrier bearing and other failures if abused. It has lots of aftermarket support but limited available ratios if you are using the stock Rubicon differential.
21. GM 12-bolt
Similar to the GM 10-bolt. It has a flexible housing and weak tubes for a full-width axle. It's not really a good 4x4 axle worth swapping into a Jeep.
20. Toyota 8-inch
Overall, it's a stout axle for its compact size. It actually makes an OK Jeep swap, but is often frowned upon for being an import part. The Toyota 8-inch has lots of aftermarket support.
19. Alum Dana 44 (ZJ)
It's a decent, relatively durable axle, but there isn't much aftermarket support because it's fairly uncommon.
18. Chrysler 8.25
It's a decent axle when mated with moderate-sized tires, however, few gear ratios are available. It doesn't have much aftermarket support.
17. Ford 8.8 (Ranger and Explorer)
Some versions have weaker 28-spline shafts. The '91-'01 Explorer 31-spline version is preferred ('95-and-later have disc brakes). There's a lot of aftermarket support for the 8.8, but the C-clip shafts are a notable weakness. Commonly swapped into Wranglers in place of the Dana 35, although the marginal gain in strength hardly seems worth the effort.
16. Toyota Land Cruiser
They're getting harder to find, but they're still usable for a Jeep in need of an offset rearend, albeit an expensive oddball possibility with C-clips. An offset Dana 44 from a Quadra-Trac FSJ would be a better option.
15. Ford 8.8 (fullsize version)
All have 31-spline shafts and undesirable C-clips retaining the axles. Not a particularly good full-width axle for a Jeep swap.
14. Dana 44 (non-Wrangler)
Much like the Dana 44 front axle, the 44 rearend enjoys a lot of aftermarket support in the form of optional ratios, floater kits, and aftermarket differentials for more traction. Some early models are plagued with small bend-prone axletubes, weak coarse-spline shafts (as well as two-piece shafts), and coarse-spline pinions. Early '70-and-later Dana 44 rears are much more desirable. Look for 2 3/4-inch axletubes and 30-spline, one-piece shafts.
13. AMC 20 (FSJ)
The FSJ AMC 20 is stronger than the CJ version and perhaps about equal to the strength of a newer Dana 44. However, it doesn't enjoy as much aftermarket support as the Dana. Fewer gear ratios and lockers are available.
12. '07-and-later Wrangler (Rubicon only) Dana 44
It features stronger tubes than the axles in the previous model Wrangler and 32-spline shafts. It's sure to see plenty of aftermarket support, including complete assemblies available from Mopar.
11. Chrysler 9.25
It's only found in Dodge trucks and vans. Even though it's relatively strong, it's not all that great of a swap for a full-width axle. Very few ratios and aftermarket differentials are available for the 9.25. It's also a C-clip axle.
10. Ford 9-inch
It's the king of aftermarket components. The 9-inch came in Ford cars and trucks and can be found in many configurations, lug patterns, and widths; junkyard versions are becoming more difficult to find. Look for the stronger 31-spline versions over the weaker 28-spline. Most axles can be converted to stronger 31-, 33-, 35-, and even 40-spline shafts with bolt-on parts. Plenty of differentials are available and gear ratios ranging from 2.80:1 to 6.50:1 are easy to find. Complete aftermarket housings and entire assemblies are available.
9. Full-floating, 30-spline Dana 60
These are extremely common and can be easily found in junkyards under Dodges, Fords, GMs, and Jeeps alike. They are most often found under 3/4-ton vans and pickups, but a few came under Mopar musclecars. There is a lot of aftermarket support for the Dana 60.
8. Semifloating Dana 60
It's a little rare, but it can be found under early F-150s and early-'70s FSJ pickups. It features desirable 35-spline shafts and uses common Dana 60 gears and carriers, so a lot of aftermarket ratios and differentials are available.
7. Full-floating Ford 10.25
The ring gear is huge, but aftermarket support is not. The gear ratios and differential selection is limited. Heavy use will also cause the axletubes to break free and rotate inside the centersection. Not a great full-width swap.
6. Full-floating 35-spline Dana 60
They enjoy plenty of aftermarket support because they use common Dana 60 gears and carriers. However, they're very uncommon, and you're not likely to find one in a wrecking yard. Many 35-spline 60 rear axles have been converted from 30-spline housings.
5. Rockwell 2 1/2-ton
Rockwell rear axles are often two to three times less expensive than their frontend counterparts. The housing, gears, carrier, and bearings are extremely durable. The 16-spline axleshafts are not. Aftermarket shafts are available to bring it above Dana 80 strength. Only one gear ratio and few lockers are available. Due to size, 6.72:1 gearing, and weight, it's not a good axle for tires less than 44 inches tall.
4. Full-Floating GM 14-bolt
The 14-bolt is the king of cheap beef when running tires up to and more than 44 inches tall. You can't deny the strength of the 10 1/2-inch ring gear, huge 30-spline pinion, and 1 1/2-inch, 30-spline axleshafts. It also enjoys a decent number of aftermarket gear ratios and differentials. The fact that it has a removable pinion support and spanner adjustable backlash makes 14-bolt gear and differential swaps relatively easy. It can be found in GM 3/4- and 1-ton trucks and vans in a few different widths. It's often found in wrecking yards for less than $200 because it's so common. Perhaps its only real weakness is the thin tinfoil-like diff cover.
3. Full-floating Dana 70
The Dana 70 is another member of the cheap beef squad. However, there are several versions making them more difficult to identify. Look for the Dana 70U or 70HD. These feature desirable 1 1/2-inch, 35-spline shafts. There are also plenty of ratios and a good number of aftermarket differentials available for these versions of the 70 as well. They are often found in 1-ton Dodge, Ford, and GM trucks, vans, and even some tractors and heavy equipment.
2. Full-floating Dana 80
This is the step into medium-duty truck axles. The Dana 80 is more axle than most people will ever need. There are plenty of ratios available that range from 3.31:1 to 5.38:1 and a good number of aftermarket differentials.
1. Full-floating Dana 135
The Dana 135 is found in some Ford F-550 medium-duty trucks and motorhomes. It features a removable third member like a Toyota or Ford 9-inch. However, its size is more on par with an 18-wheeler rear axle. The massive size and heavy-duty design make it undesirable for all but the biggest-tired Jeep swaps.
19. Dana 25
18. Dana 27
15. Toyota 8-inch
11. Chevy 10-bolt
5. Dana 50
27. Dana 25
26. Dana 35
24. AMC 20 (CJ)
23. Chevy 10-bolt
21. GM 12-bolt
20. Toyota 8-inch
18. Chrysler 8.25
13. AMC 20 (FSJ)
11. Chrysler 9.25
10. Ford 9-inch
