I wonder if the CCA would go up if it's fully charged?
AI Says:
Based on the readings shown on the Topdon BT100 tester, the battery is in fair health and a good state of charge, but is showing some signs of aging. The tester itself indicates "GOOD BATTERY".
Analysis of Readings
Reading Value Analysis
Health 61% This indicates the battery has 61% of its original capacity. The typical industry standard for replacement is when health drops below 80%, with most experts agreeing replacement is necessary below 70%. At 61%, it is nearing the end of its useful life, especially in cold weather.
Charge 70% A voltage reading of 12.42V corresponds to approximately a 70% state of charge. A fully charged battery typically measures 12.6V or higher when resting. This indicates the battery needs to be recharged to prevent further sulfation damage.
CCA Tested 626 CCA The tester measured 626 cold cranking amps (CCA). This is compared to the rated 800 CCA.
CCA Rated 800 CCA A healthy battery should deliver at least 90% of its rated CCA, which would be 720 CCA in this case. The measured 626 CCA is below this threshold, indicating reduced performance under load.
Internal R 3.95 m? Internal resistance increases as a battery ages. While there isn't a universal "good" number for all batteries, a value of around 3-4 milliohms is common for a battery showing some wear but still functioning.
Summary
The tester has determined that the battery is technically "GOOD", as indicated by the green LED and message on the screen. However, the specific readings suggest the battery is aging and losing capacity.
It is currently undercharged and should be fully recharged as soon as possible.
While it still functions, its capacity loss (61% health, 626/800 CCA) means it may struggle to start the engine, especially in very cold temperatures.
You should monitor the battery closely and consider replacing it proactively to avoid being stranded. Would you like to know some signs that indicate it's time to replace the battery?
