Horn
I might have posted about this before, but today was the last straw, or socket as is the case. I’ve had reasonably good luck with cheap tools for the most part. I had an inexpensive mechanics tool set I got years ago from Amazon that has ridden around in the Jeep for probably 8 years and was my go to set. Still is since it turned into a garage set this summer after the clamshell case fell apart. The same kit was no longer available, so this fall I ordered a different equivalent. Worst set ever. None of the sockets or extensions stay together, which can be maddening working in tight quarters when sockets keep falling off. To add insult to that, I’ve now broken the third socket. I barely put any force in the 13mm this morning before it split. There is almost no metal where the socket is cut, and they are all like that. Almost worse than useless since they are taking up the space of good tools, and guaranteed to break when you need them on the side of the road. Next set will be higher quality.
